DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Ram Van
Thread Tools Search this Thread
Old 10-24-2009, 08:01 PM
zanko79 zanko79 is offline
1997 Dodge Ram 2500
Default My heat blows warm air please help
My heat suddenly start to blow warm air any info on what i should start looking at to get it fixed.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-24-2009, 08:08 PM
alloro alloro is offline
Are we to assume that it was blowing hot and now it only blows warm, or do you mean that you can't get cold air to blow out of the vents?
Old 10-25-2009, 04:10 PM
1997 Dodge Ram 2500
Quote:
My bad i was in rush when i wrote that post.My heat doesn't work anymore, it used to blow very hot air know it's warm please help if you can
Old 10-25-2009, 08:48 PM
Is your gauge showing that the engine is coming up to full temperature? If not replace the thermostat. If the engine is coming up to temperature, then either your heater core needs a flushing, your coolant is low, or the blend door isn't moving.
For the blend door, remove the glove box and the blend door motor is right there. Start the van, turn the heat on, then turn the temperature dial up and down. Watch for the motor to move and the linkage rod running to the blend door to move.
Old 10-26-2009, 02:25 PM
1997 Dodge Ram 2500
Thank you for your help, engine is coming up to temperature, coolant level is good, heater core dont know if needs flushing i m gona have to look that up to see where is? I m gona assume that it is a blend door since when i move from cold to hot there is not that much difference in air tempature and again thank you very much for your help
Old 10-26-2009, 05:28 PM
The heater core is under the hood on the passenger side, in that big black box. If you look back on the firewall you'll see the two heater hoses going to it. To flush the core you would have to disconnect those two hose from the core, then blast water through the tubes the hoses came off of. At least once in each direction.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
