DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Ram Van
Thread Tools Search this Thread
Old 11-07-2009, 01:25 AM
ASAP ASAP is offline
Default 1998 Ram Van 1500 wont start unless boosted
I have a 1998 dodge ram van b1500. Randomly, one day the truck decides not to start. Instead of starting, it makes a clicking noise when i turn the ignition. I decided to change the battery, since the guy i had recently bought it off of said he had never done it, and the car still wont start. But it starts when boosted.
Im thinking ether the wire connectors, or something in the starter, but i dont really know. Any help would be appreciated!!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-07-2009, 02:50 PM
alloro alloro is offline
Quote:
Originally Posted by ASAP View Post
I'm thinking ether the wire connectors
Me too. Clamping the jumper cables on is probably just enough additional pressure to improve the connection from the battery post to the cable.
Old 11-08-2009, 12:38 PM
So what fix is necessary? is it the connectors in to the battery terminals? or do you think that it would be the starter solenoid?
Old 11-08-2009, 01:39 PM
landyacht318 landyacht318 is offline
When you jump it, are you putting the black on the engine, or on the battery?
If on the engine this might indicate a bad ground to the engine from the battery.
Always start these types of problems by eliminating the battery connections/cables and engine and firewall grounds as the culprits.
Old 11-08-2009, 03:25 PM
I always put it on the battery. I could try to put it on the engine, i guess that would eliminate one thing... i will let you guys know!!!! thanks for all the help btw
Old 11-08-2009, 03:57 PM
Since you put both jumpers on the battery terminals, I believe Alloro's response was the most likely. The extra clamping pressure of the jumpers is enough to cause a better connection between the cables and battery. This should be remedied my a good cleaning until the battery terminal lead is as shiny as aluminum foil.
Also check your battery cables for green or white corrosion. Also check the connections at the starter, and the main engine ground.
The jumper pack itself will not have enough juice to by itself to crank your engine.
There is also the possibility that one of the relays has some corroded terminals. Starter or ASD.
Old 11-08-2009, 07:10 PM
I fixed it!!!!!! just a good cleaning of the terminals, thats all that was needed. Thanks a million guys!!!!!!
Old 11-08-2009, 07:25 PM
Congrats! It's a good feeling to be able to fix something without having to pay someone else to do it. Especially when it is something so simple.
Old 11-08-2009, 07:39 PM
Just leave a quarter in the bucket on your way out the door.
Old 11-08-2009, 07:54 PM
haha i love it. Such a simple fix for the problem. Never would have thought about it.
thanks again guys!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
