Trouble changing water pump - DodgeForum.com
Old 08-06-2015, 02:52 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Cooling System
Print Wikipost
Old 05-06-2011, 05:46 PM
Ramvan1
Ramvan1 is offline
Question Trouble changing water pump
Hi I'm trying to change the water pump on my 2000 Ram 1500 van and can't get the fan clutch off I have the special tool but it won't come loose which way do you turn the bolt if you're underneath facing the front I've been turning it clockwise from the back because I read online it's counter clockwise from the front can anyone figure this out because now I have no car and have to walk everywhere. Also what kind of bolts are the water pump pulley bolts and where are they located I read they were allen bolts.
Old 05-07-2011, 04:22 AM
stev's Avatar
stev
stev is offline
Talking
All your answers to this can be found in the search query.
OK, I'll save you the troubles ...
http://dodgeforum.com/forum/dodge-ra...pump-dies.html
This will answer how to get the fan, clutch and water-pump off. Expect a few hours of fun getting this job done. BUT, it will save you $$$$$.
As you read through the posts, you will glean a good deal of help just before the step-by-step instructions are shown.
Old 05-07-2011, 06:07 PM
Ramvan1
Ramvan1 is offline
I tried using a pry bar to hold the pulley but it still spins and I don't know which way the nut needs to be turned from underneath.
Old 05-07-2011, 06:25 PM
stev's Avatar
stev
stev is offline
Did you follow the link? The pry bar did nothing for me either. I had to removed the water-pump and the fan+clutch assembly from the engine. Once removed, place the water-pump into a good vice, then take a saw-zal to the nut, but spaced where my threaded post says, this is how you can then separate the two.
Old 05-07-2011, 06:36 PM
Ramvan1
Ramvan1 is offline
Also if anyone knows which way the engine turns on a 5.2L motor that would be a big help.
Old 05-07-2011, 09:41 PM
alloro
alloro is offline
Van & CUV Section Moderator
Dodge Forum Moderator
Quote:
I'm 99.99% certain it's clockwise if you're standing in front of the vehicle and looking at the motor. You can look at the pitch on your fan and figure it out. Naturally you will need to look at your serpentine belt routing and see if the fan turns the same direction as the motor.
Old 05-08-2011, 04:40 AM
landyacht318
landyacht318 is offline
I know my v belt LA (non magnum) 318, all the belt driven accessories turn clockwise, and the magnum serpentine belts turn the h20 pump CCW and the water pumps are not interchangeable between the 2 for this and probably other reasons.
Old 05-08-2011, 05:08 AM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Mobile Auto Repair is offline
On a 99 van I cut the fan nut off with a saw-zal while the pump and fan were still on the engine. Changing that pump with new fan clutch, t-stat, by-pass hose, top radiator hose, heater hose, new belt, idler pulley, and serpentine tensioner unit took me 3 hours.
Old 05-08-2011, 02:28 PM
Ramvan1
Ramvan1 is offline
I really didn't want to cut the fan clutch off cause it still works fine. Is there really no way to hold the pulley I think i'll try channel locks. if anyone finds an idea as how to hold the pulley please reply.
Old 05-08-2011, 02:59 PM
alloro
alloro is offline
I use a chain wrench like this to hold pulleys.
http://www.grainger.com/Grainger/VIS...in-Clamp-6C664
Related Topics
Thread
Forum
Replies
Last Post
Khris1994
2nd Gen Ram Tech
121
10-24-2015 03:47 PM
JeeperDon
1st Gen Durango
15
08-20-2015 08:32 PM
slowmotiongenius
Dodge Stratus
13
07-15-2015 11:12 AM
Dalbert
Dodge Ram Van
8
07-08-2015 11:33 AM
rickluc
3rd Gen Dakota
1
07-08-2015 10:26 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
