Rear Blower/Fan Motor Location
The unit sits along the driver side wall of the van under the second bench seat. A standard phillips screw driver takes off the cover. Just be easy on the plastic cover and the fasteners. Don't want the RAD to leak due to a screw puncturing it.
The fuse is located on the driver's side dash on the very far left when you open the driver's side door. Pop off than panel.
