ABS and AIRBAG lights intermittant
I searched this forum and a few people have had this same problem, but no one has mentioned what the ultimate fix was.
This is a 2000 B350 van.
Occasionally after "key on" all the dash system warning lights cycle as normal, but the ABS and AIRBAG lights will come back on and stay on. Vehicle starts and runs ok, but sometimes I have no speedometer with these lights on.
No error codes are recorded.
It's an intermittent problem.
The options I found were:
1. ABS sensor (which one?)
2. Ignition switch
3. Bad instrument cluster connections. (I have reseated cluster connections, but no change.)
4. Clock spring needs replacing.
So, what was the real -permanent- fix?
Thanks
2. Ignition switch
Thanks
Update on this issue. I seldom use this van and the only reason I have it is for hurricane bugouts. To review, I was having an issue with the air bag and/or ABS and/or brake idiot lights intermittently staying on after engine start.
I changed speed sensor on top of diff (easy and abt $25.00) -- no fix.
I changed transmission speed sensor on tranmission (easy and abt $25.00) -- no fix
Finally changed ignition switch assembly (a PITA and about $140.00) -- FIXED !
