combination vlave replacement
combination valve replacement
hi, my combination valve seems seized inside. the brakes have always been a bit crappy at the rear and now its failed its annual mot test (im in the UK) so ive replaced all shoes & pads, new master cylinder, checked the booster as in manual (engine off, pump three times to stiffer pedal etc) about to install new wheel cylinders and then a good long bleed.
After inspecting everything, i noticed the combination valve front "pin" doesn't move in and out as described in the manual when brakes are depressed. After grabbing it with pliers i managed to work it looser but still no movement on its own. i think the spring behind it must be seized? also i noticed the electrical pin/connector on top was at an angle but doesn't ground to earth to throw the warning light on.
Anyways i cant find a rebuild kit and im told these are discontinued. does anyone know of an aftermarket match for our vans? its got rwal so it'll need to connect with the anti-lock block thing.
if i leave it as it is can i still bleed the brakes and get pressure back (the pedal currently goes to floor)
mines a 1993 ram wagon b250, 5.2 v8, 11" rear drums, RWAL, .
thanks
thanks
I suspect you'll find out if the valve is working when you go to bleed the rear brakes. Assuming the lines are good and you're putting in new cylinders, if you can't get any fluid out (or barely trickles) then you probably have a bad valve.
Be sure to do slow, steady presses on the brake if doing the manual bleed method (not fast, hard!).
well, i had another search for the right tools and just been out to buy these.. huzza!
http://www.machinemart.co.uk/shop/pr...nut-wrench-set
still waiting for the cylinders to turn up. So no wim gonna go out and see if i can get the combi-valve off and clean it out in the garage. im hoping it will free up and not need new rings and spring...cos i don't got them!
Trending Topics
so i took off the combi/prop valve ( twisted off a nut in the process..ouch!)
and here is what was behind the stem, a crusty mess. i pulled the other bits and cleaned them up. I also managed to dissasemble more than it shows in my picture, beyond that crud is a a round plastic plate, a hollow shaft a, a rubber plunger, big spring, little spring and a tiny spring and e-clip.. which was loose! after a lot of head scratching i guessed how it went back together and its now reassembled. sorry theres no pic of that bit. luckily all the rubber parts were intact.
found this great writ up which showed me how to pull out the pressure diff valve. (although i just used a screw and it came loose)
https://www.musclecarresearch.com/1979-gm-kh-combo-valve-autopsy
