oil pressure light.
oil pressure light.
I am new to Dodge vehicles, but my 95 b2500 has a problem. I was driving today and after about an hour the oil pressure dropped and the oil light came on, I pulled over and shut it off for about 30 seconds and restarted, and the pressure was fine. It continued to do this all the way to my house. Does anyone have any ideas? Thanks
If the oil level is correct and recently changed with a new filter, about the cheapest part to throw at the problem is the oil pressure sending unit. Less than $20 over at rockauto.com
Maybe you can help yourself by doing a search on this forum for "oil pressure" -- then give us some more information so we can help you.
Trending Topics
Suggest you change the oil pressure sensor or install a real (mechanical) oil pressure gauge. As mentioned in a previous post you can run both.
A well worn engine may not make any unusual noises even pressure drops to almost nothing. If your oil pressure drops below 5 - 6 psi after the motor is warmed up it usually means the main bearings are gone.
