92 B350 igintion switch not always starting
Old 10-13-2014, 12:25 PM
wpatters129's Avatar
wpatters129
wpatters129 is offline
Default 92 B350 igintion switch not always starting
92 B350 sometimes when I try to start it just makes a click but then other times it starts right up. Always starts really quickly. Not sure if this is bad contacts in the ignition switch on the column or something else. Have checked the battery connections, replaced the neutral switch on the tranny. Sometimes you have to put it in neutral.....this time it was doing it and it would click and then you try again and it starts like there was nothing wrong. I have had this on other cars where it turned out the solenoid on the starter did not make good contact when the contacts as they went forward to engage with the starter and flywheel. Could that be the problem that those contacts are shot? Used to be you could adjust that throw so they made better contact after they wear. Any ideas?
Another question: Can the solenoid that sits on top of the starter be adjusted for worn contacts? Do I have to buy a whole new starter or can I buy just the solenoid and the contacts associated with that?
Quick Reply: 92 B350 igintion switch not always starting
