Cranks but won't start
Old 10-20-2014, 07:31 PM
Tvwallace's Avatar
Tvwallace
Tvwallace is offline
Default Cranks but won't start
Our church van, 1991 B350 with 5.9 will crank but won't start. New coil along with complete tune-up with no results. I show 12 volts on both sides of the coil.
Thought I would replace crank position sensor and distributor. The crank sensor that is in the van has a 2 wire connection. The auto parts only have 3 wire connections.
Need to get repaired to pick up the little ones. Any help would be greatly appreciated.
Thank you,
Tom
PS first time user. Trying not to have it towed to repair shop
Old 10-21-2014, 12:04 AM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Dodge Forum Moderator
Crank sensors have 3 wires. A positive, a negative, and a trigger wire. Perhaps your 3rd wire broke off the connector and that's your no start problem.
Quick Reply: Cranks but won't start
