Ram Van Pony Boards for Regency Conversion
Clearly nobody here has any idea what on earth a "pony board" is so if you wanna elaborate, I will attempt assist you.
Are you referring to running boards by any chance? There were custom made per conversion supplier and are for the most part no longer available as each customizer used a different type/style. If yours are ABS plastic they are likely a lost cause and not repairable.
If they are one piece fiberglass runing board/fender flares then there may be local body shops and several here who are skilled enough to repair and repaint them.
If you just need advice as to how to repair fiberglass I recommend you check out "fiberglass hull repair" on youtube.com and that should pretty much teach you everything you need to know.
Simple, The Ram Van is a cargo version sold to the conversion company in 2003. After the conversion, they offer the van as a 2004. However, when looking for Ram Van parts it;s 2003, looking for the conversion parts is 2004. Had this on a 2000 B1500 Ram Van by PrimeTime as a 2001.
Owens Products makes running boards available for Dodge vans. Look up the part numbers on their website and can order them through Amazon.
http://www.owens-pro.com/
