Higher wattage dome light
those bulbs can get pretty hot even with the standard wattage
I would bet you would melt the lens.
LED is the way to go. I did mine with a flat panel LED and it lights the interior well. I did it so long ago I cannot tell you the type, but as I recall you can buy LED flat panel bulbs with universal socket fittings of various sizes. Measure your lens fitting and purchase the correct size as the panel just lays on the lens. Most LED bulbs measure less than a watt so is efficient on the battery. I also ran power wires from that socket and installed side LED fittings just behind the front seats, and another pair at the back door. These light up the area just fine if I am trying to read at night or trying to find something.
Trending Topics
I've been playing around with LEDs lately and for the interior I found these to be the best, so far. http://www.ebay.com/itm/281593705350
My one gripe is the color is too blue for my tastes, but they are brighter than all other direct replacement LEDs I've tried.
maybe our dome lights are different? but those are nothing like what mine uses....
Just an update, I found a killer deal on some LEDS, they are 194 sized, but should still outperform the 906 bulbs I currently have....
I got 20 bulbs for $3.95 shipped off ebay
here are the stock 906, rated for 9W@12V:
and here is the size of the 194:
just did a google search, I definitely don't have the stock dome light, mine are rectangular housings, with 2 light pods and switches per housing. I also have about 10 of them throughout the van. They actually don't have a lens, the bulb sits in it's own reflector, but the pod is actually open, just has a crossbar over the opening
and here are the bulbs I got:
I will post comparison pics once I get them and I get a chance
my lights are in, I just haven't gone to get them yet.... long story.....
I have a total of 5 dome lights, the 4 in the back are single units, and they don't have a lens, the front unit is between the front seats on the roof, and is the same look to it, but houses 2 bulbs... still 6 bulbs total..... they are definitely not the stock housings
maybe I will put some of those bulbs in the gauge cluster too
