B2500 frame question??
Why would you assume Ram PU suspension would be identical to a Ram Van?
A B Van likely has a 1000 lbs heavier curb weight and the front axle carries more weight than a PU.
Still not sure why your curious but you can always contact a salvage yard or dealer and they can compare part numbers and tell you which parts are interchangeable.
I want to do some upgrades to the suspension and if I was a betting man I would say the P/U suspension is direct fit. But if it is not, well then I will do more research and find what I am looking for. Just thankful for web sites like this to help each other out.
Thank you all for your help.
Doc.
Well today was a good day to find some info by mistake and it was great news. Found this info and it answered a lot of my questions.
Throughout their life, the B-vans had rear leaf springs and shock absorbers, with an independent coil front suspension. Steering was power recirculating ball, with a tight turning radius for most of the B-vans’ lifespan (ending with the 1998 changes).
Chris Coleman added, “The B-van was a unibody design that used two full-length open U-channels welded to the floorpan to reinforce the body structure. Although the B-van shared components with the Dodge truck line, such as suspension, brakes, driveline, and steering components, it never used a true frame. Like most unibody vehicles, it had a separate bolt-on front K-member to carry the front suspension, steering, and engine.”
If you want to read more about the amazing AB body of the Dodge brothers, here is a link.
http://www.allpar.com/trucks/b-vans.html
Doc.
Doc.
