How do I remove the seat bolts from the floor
I have a 2002 1500 conversion van. I removed the middle captains seats as we're using the van for camping. Going to remove the bench seat and build a bed in place of the bench seat bed. I would really like to remove the bolts that held the middle seats in to then make it flat as the nuts are what stick up inside. I admit I have not yet crawled under to see if that is where I can have my hubby get access to them. Any assistance or suggestions will be greatly appreciated
Well in my Elk conversion...
The rear bench does fold down into a bed. Most conversion benches do. There is a handle under the seat you pull and then at the same time pull the bottom of the bench forward.
Also in my Elk, the rear bench in bolted down with huge wing nuts. So no wrench is needed.
Now some seats are bolted down with a bolt and nut. You would put the box end of the wrench on the nut. The bolt's top actually needs a 3/8s or so socket and has to be held and you loosen the nut with the box end wrench.
