No Reverse Lights on 2002 Van
Old 08-08-2016, 09:55 PM
quadman21's Avatar
quadman21
quadman21 is offline
Default No Reverse Lights on 2002 Van
I own a 2002 Dodge Ram 2500 Cargo Van. The reverse lights are not working on it. I changed the Neutral Safety switch and that did not work. Is there a fuse or relay switch that I may be missing? I checked so see if there was any juice at the bulbs when in reverse and there is none. Does anyone have any suggestions or advice? Thanks
Old 08-09-2016, 07:45 AM
jkeaton is offline
Dodge Forum Administrator
There could be a fuse, yes.
Old 08-09-2016, 09:38 AM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Dodge Forum Moderator
At the neutral safety switch connector...the 2 outside wires are the reverse light circuit. One wire goes to the bulbs and the other has +12v with the key on. If the power is there then the problem is from the switch to the tail lights. If there is no power then the problem is from the switch to the fuse box.
Old 08-09-2016, 10:45 AM
quadman21's Avatar
quadman21
Thank you both for the reply. I will do some more exploring on the issue this evening. The tough question would be if any of you know what fuse that would be? I thought I did a pretty good job checking the fuses but I could not find a fuse directly related to just the back up lights. Thanks again guys!
Quick Reply: No Reverse Lights on 2002 Van
