Wiper motor wiring and voltage
Darn, I realized i posted this in the wrong forum. Sorry for that, i'll delete it from the other thread.
My wiper motor was not functional when i got the wan and i realized the motor itself was broken. Ordered a used one but the connector did not really fit, so i made my own temporary "adapter" just for testing. Still don't work. (Yes, all fuses are ok).
First question since it has never worked: how do i know what position i have it in? If i turn the wiper wheel back (clockwise if you stand on the driver side and look at it) it should be off..?
Second question: what voltage should i expect on the connectors in the picture attached? Which one does/is what and in what positions on the wiper controlo wheel should i expect what?
Thanks in advance!
Thanks in advance!
Alright, my Hayne's manual has a bit of info on the wipers.
For 1991 through 1997 Intermittent Wipe Switch Continuity (position and continuity listed)
OFF Pin 6 and 7
DELAY Pin 8 and 9, 2 and 4, 1 and 2
LOW 4 and 5
HIGH 4 and 5
Max delay position resistance should be between 270,000 and 320,000 Ohms
Min delay position should be close to 0 Ohms (0 Ohms when meter is set to high range)
Steve
OFF Pin 6 and 7
LOW 4 and 5
HIGH 4 and 5
Steve
