95 b2500 shuts off randomly
i have a b2500 6 cyl. it will start then shut off ,motors stops when slowing down,also will have no throttle response while driving then cut off with sputtering and will not start back until press gas and let set for couple mins. i have replaced tps, complete tune up, any help would be apperciated
Hey, I will make this short. Your problem sounds a bit like mine. 3 months ago I put a new fuel pump in my 2000 ram van 1500, 318ci. 4 days ago my van had been running fine for the 3 months and just started to lose power, miss and sputter to a stop. Waited a few minutes, started up fine and died after a couple minutes. I did not think it was the fuel pump because it was new. I had a lean code coming up and started checking all the electrical, battery, relays , IAC, fuses etc.
Finally, I read the instructions to the fuel pump install and I had missed a step. I had never filled the tank. The pump motor did not have enough fuel down in the cup to keep it cool so the ASD was shutting it down. I opened the trap door, pulled the pump, manually filled the bottom of the pump, put back in and it has been running fine all day today after filling the tank.
I made a mistake and I hope this helps someone.
