Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
P2225 code
Old 09-20-2011, 03:09 PM
ava13181's Avatar
ava13181
ava13181 is offline
Default P2225 code
06 Sprinter. I replaced the circuit board in the transmission along with the updated harness connector. ( black o-ring one ). Checked the wiring harness to the tcm and to the shifter. All okay. Can the tcm be repaired or tested. Vehicle has 2nd and reverse. It shows on dash but will not shifter side click other gears there. Any help would be greatful. Tony
Old 09-20-2011, 11:31 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Welcome to DF
Tony I have PDF files I can send to you by email. Just pm your email and I'll send it.
Old 09-21-2011, 12:07 PM
ava13181's Avatar
ava13181
ava13181 is offline
tvanarem@gmail.com thanks so much, Tony
Old 07-08-2013, 08:22 PM
Goldtrader11's Avatar
Goldtrader11
Goldtrader11 is offline
Default same problem
hi,
i have the same problem, how did you fix it? thanks for your help..
Old 09-09-2014, 07:08 AM
mani's Avatar
mani
mani is offline
Quick Reply: P2225 code
