Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
dodge sprinter
Old Apr 14, 2013 | 07:17 PM
froman2424's Avatar
froman2424
Default dodge sprinter
i have a 2008 dodge sprinter my battery is fully charge i jump start the starter it works but when i try to start the van with the key all the light in the dash came on fine but with the key allaway it wont start of nothing in a little while i hear a click onder the dash and the lack pop up also the drive shift wont move from park can anyone help please
Old Dec 8, 2013 | 06:08 PM
Nelson Sprinter's Avatar
Nelson Sprinter
If fully charged, there may be a poor connection at the starter, or ground is corroded . Clean the battery terminals, wire connections, grounds with sandpaper and lube with Vaseline, replace to battery.
If the gear shifter won't move the bake switch may be worn/broken, or the ECU is not getting a strong signal from it due to this wiring/voltage problem.
It can be over-ridden by placing a pen/pencil in the hole at the gear selector.
