92 r/t still won't start ecm rebuilt by ecmtogo
okay guys, i sent the ecm to ecmtogo, they found a problem, rebuilt it, sent it back installed it into the car. now get this, its got spark(installed new plugs-it turns over-excellent fuel pressure-200# compression-injectors are working fine-cas installed correctly, it tries to run on a few cylinders, but won't run at all. could it be a bad ingition switch on the run side of the switch?? the dash lights-a/c-heater-etc... are working inside the car, so the wiring harness must be okay, what are we overlooking??? any ideas out there?? i'm loading the bazooka!!!!!!!!!! if the coil packs were bad, shouldn't that show up as a spark problem?? according to the timing light, spark is real good. i'm desprite here. can anyone call me at 1-717-577-3522 with any suggestions???
