DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stealth
Thread Tools Search this Thread
Old 12-05-2008, 09:26 AM
93stealthes 93stealthes is offline
Default help plz!
when i change my spark plugs do i have to take off the intake manifold to get tho them or is there a special way to do it? i have a 93 stealth es, dohc. help will be very much appreciated, and if i have to take it off do i have to but a new gasket?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 12-05-2008, 11:36 AM
yevgenievich's Avatar
yevgenievich yevgenievich is offline
The Moderator
Dodge Forum Moderator
1989 Pontiac Firebird
My Garage
Vehicle: dodge stealth, t/a, camaro
Send a message via AIM to yevgenievich
On DOHC motor you have to take the intake off to change the spark plugs. You don't have to replace the gasket unless it brakes on you.
__________________
Old 12-16-2008, 12:47 PM
ok thanks, and if my car wont start when its hot well normal running temp, wouldnt that be an overheated coil pack, it try to turn over cut i dint think its getting any spark, so im thinking ita a bad coil pack or distrisutor or something along those lines, my check engin light come on also but only when it is at normal running temp, it dont come on when its kool or warming up at all. some hepl would be appreciated.
Old 12-19-2008, 10:10 PM
The Moderator
My Garage
have you checked what the engine light is on for?
here is a link to check the codes:
http://www.stealth316.com/2-diagcodes91-93.htm.
You might be either not getting fuel or spark. Will it stay running when it reaches operating temp?
__________________
Old 01-06-2009, 12:22 PM
bad venge's Avatar
bad venge bad venge is offline
Section Moderator
1998 Dodge Avenger
Vehicle: 98 Dodge Avenger
Get the codes scanned , that might give you a key to the trouble ...
Old 06-17-2009, 01:21 PM
ok well i changed my plugs an thts not the problem. i checked the coils an there gettin spark to the wire. but my check engine light is still on an it runs fine when at normal operating temp but it still wont start when its hot. an when im drivin down the road at a decent speed ill turn it off an pop the clutch an it starts up but runs like crap in lower rpms an idels at close to 2grand. when i give it gas after i pop the clutch it the rpms drop down to 500-1000 and starts to jerk a little bit then it will go. if any one can help it will b very much appreciated THANKS A BUNCH!!!!
Old 06-17-2009, 01:25 PM
o forget somethin lol...none of the local places will scan it because it is under a 96 which i think is gay an i tried the ignithion trick an i cant get it to work. an the wire for my car to scan it is 200 DOLLARS lol thts alot for just a wire lol. i appreciate the help.
Old 06-18-2009, 01:01 PM
Exclamation help please
my stealth wont start while at normal operating temp an i changed my plugs an thts not the problem. i checked the coils an there gettin spark to the wire. but my check engine light is still on an it runs fine when at normal operating temp when its started while cooled down but it still wont start when its hot. an when im drivin down the road at a decent speed ill turn it off an pop the clutch an it starts up but runs like crap in lower rpms an idels at close to 2grand. when i give it gas after i pop the clutch it the rpms drop down to 500-1000 and starts to jerk a little bit then it will go. if any one can help it will b very much appreciated THANKS A BUNCH!!!!
Old 06-19-2009, 01:08 AM
The Moderator
My Garage
check the computer for blown caps, should be located behind the radio if i remember right. Also try the voltmeter trick to check the codes.
__________________
Old 06-19-2009, 01:23 AM
ok thanks. can i change the caps if there blown? an how do u do the voltmeter trick to check codes?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
