DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stealth
Thread Tools Search this Thread
Old 05-06-2009, 04:34 PM
buck6680 buck6680 is offline
Default 91 stealth TT ignition problem
91 stealth TT. Car hasn't run for over a year when I bought it recently. So far I have replaced the fuel pump, installed a rebuilt ecu, installed a used cas, & power transistor, and got the car running again. It ran good for a short while, (a couple of minutes), then started missing and check engine light comes on. Upon checking, I determined it wasn't firing cylinders 3/6, so I replaced the coil pack with another used one. Again, when first started, it will run good, then begin missing again w/the check engine light. I checked for codes and came up with code 53. Thinking maybe the plugs were fouling, I just replaced all of them. Again when I first start it, it runs great for about 1 minute or so, then begins missing again and check engine light comes on. Checked the codes again, still getting code 53. Pulled the #3 plug wire, stuck a screwdriver into the end of it and started the car again. It's arcing like crazy, so I plugged it back onto #3 plug and it runs good for a short time and then begins missing again. I pull the plug wire back off while it's running and this time no fire at all coming from the coil. Using a extra plug wire to ground, I check to see if there is any fire coming from the coil going to #6 plug, nope, nada. It appears, when the car is first started and it's in open loop, the 3/6 coil is firing, but I'm thinking that when the system goes into closed loop, the coil for some reason is dropped out.
Since then, (yesterday) I've again swapped out the cas, power transistor, and changed the 3/6 coil. The car started and idled fine for just over 6 minutes, then lost power to the 3/6 coil again. I can let it set for a while, start it back up and it will run on all six for a minute or two, sometimes a little longer, then the 3/6 coil quits firing again and the check engine light comes on. The only code I am getting is 53.
I'm lost here, does anyone have any advice/suggestions on where to look to resolve this problem? Any help would be greatly appreciated
Thanks in advance,
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-07-2009, 07:02 PM
yevgenievich's Avatar
yevgenievich yevgenievich is offline
The Moderator
Dodge Forum Moderator
1989 Pontiac Firebird
My Garage
Vehicle: dodge stealth, t/a, camaro
Send a message via AIM to yevgenievich
that rebuilt ecu might not be working right, do you have another one to test?
__________________
Old 05-20-2009, 06:06 AM
SPARTANENGINEER1701's Avatar
SPARTANENGINEER1701 SPARTANENGINEER1701 is offline
Default Hmmmmmmm
CHECK CRANK AND CAM SENSORS ,IF ecu isnt getting THE INFO IN NEEDS
IT COULD BE THINKING IT ALREADY FIRED THEM FOR SOME REASON BUT IT POINTS TO ECU PROBLEMS ,
Old 05-20-2009, 06:48 AM
dane25 dane25 is offline
Better check your ECU or sensors...
__________________
"thanE"[img]http://******************/images/2dbf21633f03afcf882eaf10e4b5caca.gif[/img]
Tags
53, 91, check, code, dodge, dogde, engine, ignition, light, lights, problem, stealth, tt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
