DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stealth
Thread Tools Search this Thread
Old 06-06-2009, 11:49 AM
BillyWing BillyWing is offline
Exclamation Help! Stalling Stealth
1993 Dodge Stealth 6 cyl Front Wheel Drive Manual 10100 miles
It's a DOHC 24V R/T non-turbo
and the Check Engine light will only come on after it shuts off which leads me to believe it doesn't actually have a code, but I might be wrong.
I bought this car a week and a half ago from a guy who said that it would stall when idling after being warm, but he would wait 10 mins and it would start back up.
A few days ago, this became very serious when it stalled for me for the first time while I was **Driving**.
I had assumed it actually just needed some cleaning where the ISC was located. So when I got it home, I took off the ISC and cleaned inside there with some carburetor cleaner and a little bit of the throttle body near the butterfly door. After letting it dry, I put it back together and tried driving it. It then stalled and became much worse. It then would not stay on for more than 2 seconds before cutting off.
After getting it home, I replaced the fuel pump and in-tank filter. It still stalled.
Today, I completely took apart the throttle body and cleaned it thoroughly.
After placing it all back together, I was able to drive it for a good 30 mins until it stalled again.
I still feel it's the ISC because 1. the engine wont rev when you turn the steering wheel 2. the a/c will only affect the rpm's for a second and then it will return back to normal and 3. When I turned the Idle screw out some, it looked like it was keeping it from stalling because the RPM's kept fluctuating when the engine was still cold.
Also: Everytime it stalls, it will stall and then won't be able to run again for a while.
Sometimes it will turn over, but then immediately stall and other times it will last a few seconds.
Also, forgot to add that it's totally at random.
It will stay running for a few mins sometimes and others it will turn on and then right back off.
And then it might just not turn over at all.
I was told it might be a short in the ECU or cam sensor.
If any other questions, please do not hesitate to ask. I NEED this fixed ASAP!!!!
email:billywing@charter.net or derdervp@yahoo.com
please do both because I don't know which will work.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Tags
dodge, engine, idle, intrepid, isc, stalled, stalling, stealth, turnover, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
