Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Clutch bypass switch
Old 08-30-2009, 08:14 PM
Tree's Avatar
Tree
Tree is offline
Location: Edwardsville, IL (North East of St. Louis, MO)
Default Clutch bypass switch
Do the Stealths have a safety in the clutch switch? The car won't start at all now. For a while I could pump the clutch and it would start. Or, can I just bypass the switch and hard wire it to register the pedal is depressed?
Thanks,
Steve
Old 07-30-2010, 09:11 PM
Twin Turbo Guy's Avatar
Twin Turbo Guy
Twin Turbo Guy is offline
Smile Yes, and do just the reverse of what you would think.
They do have a safety switch on the clutch (it's called an interlock switch) and to disable it you just have to unplug it. It is normally closed and opens when the clutch pedal is pushed. Disconnecting it has the same result. There are two switches on the clutch pedal, one that makes contact when the clutch pedal is back - this is the switch for the cruise control - and one that sits in a more vertical position, this is the interlock switch. Just follow the wires back about 4 inches to the connector, press the release on the top (it can be hard to get too) and it pulls off real easily. Hope this helps.
Quick Reply: Clutch bypass switch
