RE: TheStealth-Where is the ECS fuse?
The ECS is on the opposite side of the antenna on the passenger side. To unhook the harness you may have to A. Remove the plastic trim altogether or B. unscrew the three screws that hold the unit in place. There is a little removable cover that will let you access (almost) the unit. You will have to remove the "tub" on the passenger side of the spare to remove the cover.
Edit: It is fuse 10 under the dash, but that fuse powers other items, such as interior lighting, ECM and cruise control.
