DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 06-21-2007, 03:26 PM
john1782 john1782 is offline
Vehicle: 02 Stratus R/T
Default Problem with the battery or could it be something else?
Ran the air conditioner for the ride home from work..(about 3 miles), shut the engine off when I got home and when I tried to start the engine right back up it would barely turnover. Had my 02 Stratus service on tuesday and they told me the battery needed replaced, well did the above again today and the same problem happened. Tried to start theengine after about 20 minutes or so and it fired right up, is the above apossible problem or just normal?
Thanks, John
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-21-2007, 03:27 PM
Default RE: Problem with the battery or could it be something else?
Buying a used car = Buying someone elses problems[:@]
Old 06-21-2007, 05:15 PM
BloodRed BloodRed is offline
It does sound like you have a weak charging system. If you can take it into AutoZone. They can come out and check your battery and tell you if it is going bad. But if the dealership is telling you that, then it probably is. Just go grab a new battery and drop it in.
__________________
C.O.R.U.P.T. - www.coruptghosts.com
Old 06-21-2007, 05:26 PM
The dealership put a NEW battery in on Tuesday that's why I'm a bit concerned.
Thanks for the reply.
Old 06-22-2007, 04:57 PM
Ok you didn't say you had it replaced. I would take the car back to the dealership and see if they can find what the problem is. If that is what the car was in for originally, the dealership didn't fix the problem.
__________________
Old 06-29-2007, 05:22 AM
xx742617000027xx xx742617000027xx is offline
Send a message via AIM to xx742617000027xx
This is just a shot in the dark, but check for a parasitic drain, and like BloodRed said, your alternator could be inadequate. Id say yea, take it back to the dealership and make sure they do a draw test and then do a charging system test. But make sure that they also check for a parasitic drain. That seems very possible. Are you parking on any hills?
__________________
'97 Stratus ES
Custom Lowered (spring compression)
Kenwood deck
Audiobahn DUB 10", 4x 6x9", Amp
Open to suggestions
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
