RE: Stratus 1998 Immobilizer
the immobilizer is basicly the alarm system. Do u want the alarm or keyless entry removed?
If u want the alarm removed u cant, software is burnt inot the pcm and bcm that says it has an alarm so if u remove any part of it that part will not work correctly and either the bcm or pcm will not allow the car to start. U can bypass using the keyless entry to disable the alarm by either locking and unlocking in the driver or passanger side door,depends on where the key ring is at. Some are also in the trunk now thats also depends if the key switches are working correctly.
__________________
Work at a Chrysler,Dodge,Jeep Dealer<Master AC/Electrical/Engine Performance
Chrysler Dodge Jeep Tech for 11 plus years and do side work in ATLANTA if u need something done just email me.
http://home.comcast.net/~kkeller608/index.html
