DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 06-24-2007, 09:02 PM
taylor141 taylor141 is offline
Default Accessory signal not received by radio
Hello all,
I have a 2001 Stratus Coupe, and I have recently diagnosed a problem with my radio not turning on when I turn on the accessories (or the ignition, for that matter). The radio should be getting this signal through pin 6 in the grey connector (I have the two 7-pin connector head unit). When I turn the key, there is no signal on this pin. I am sure this is why my radio isn't working, because when I apply 12 volts to the corresponding pin in the head unit, the radio works perfectly.
I am wondering if this is cause by a fuse that burned out, or a relay that quit working. I located the fuse for the radio in the fuse box by the battery (the driver compartment fuse box does not have a fuse for the radio, perhaps because that was intended for the Inifity system). It seems like all the other accessories (headlights, air conditioning) operate when the key is in the accessory position, but this pin on the radio is not getting a signal, so it never tells the radio to turn on.
Is there anything else that could cause the signal from the ignition switch to be blocked in coming to the radio?
Thank you,
Taylor
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-25-2007, 03:45 AM
Default RE: Accessory signal not received by radio
Turns out it was the fuse after all. I checked continuity (negative), and replaced the fuse, and everything works now.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
