DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 07-08-2007, 12:18 PM
T45965 T45965 is offline
Default 95 Stratus PCM/ASD and Battery Hook up Wrong
95 Stratus 2.0 SOHC 5-Speed manual. Problem : The battery was replaced and the wrong connections were made. (How bad its that.) The PCM/ASD 20a fuse was blown. I replaced it ... hooked up the battery Correct this time and the fuse blew again. The ASD relay and starter relay both look fine. The PCM did not show any obvious shorts when I took it apart, but I'm guessing that is the problem.. I also left the PCM plugged in and removed the wires to the alternator and starter, but the PCM/ASD fuse blew again. If the PCM is bad, does it have to be personalized for the VIN number? I was thinking of looking for one at the salvage yard in the same 95 configuration as I have.. Will that work? Lastly, should I look for other shorts or damage to other components before I shell out $$$ to fix the PCM to see it blow again? Thanks for your assistance. What a costly error...I know.. [align=right][/align]
Post #: 1
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Tags
95, asd, pcm, stratus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
