RE: How to remove a governor on a 2000 stratus es.
Your car does not have a "govenor" you have speed controlled computer. Dodge does not make a computer that can be flashed to up that top speed control. The only alternative is to get a performance computer (I do not believe there is any for the Stratus) or go a stand-a-lone custom computer for your car.
Basically, yes you will always be speed controlled to 112 (actual speed), no matter how many modifications you do. BTW--The reason your car is speed controlled to 112 is because the tires that came from the factory are only speed rated up to 112. Anything beyond that and they can become very unsafe. Higher rated tires are required to make the car safer at higher speeds.
I am not giving you this information so that you can upgrade your car to street race. I hope that you only are expeirencing those speeds on a closed course. If not, I hope the cops catch you, impound your car, you loose your license and serve some well deserved jail time!
__________________
C.O.R.U.P.T. - www.coruptghosts.com
