RE: 01 Wants to die at lights
It is possible for them to come loose... Not probable... But possible. 10 years ago I stopped on the side of I-75 to see if I could help a couple with their hood up on a Mercedes. There was a spark plug wrench that actually snapped undo the top of the valve cover. It prompteded me because I saw it there to check the plugs. Low and behold two of them had backed out to a point that I could have removed them with my fingers. I used the tool that was right there, tightened them back up, and they were set.
(edit) I'm no mechanic, but the "symptoms" that you mentioned above don't sound like loose spark plug(s) to me.
__________________
Mopar or No-Car
