Help pls. Codes P0605 & P0700 on a 2001 Dodge Status Transmission
I have a 2001 Dodge Stratus SE 2.4L DOHC. the transmission won't shift out of 1st gear, i pulled the codes and came up with P0605, and P0700.
i tried searching the internet,and read a few posts,that said in/out speed sensors, and the TCM. I called the local dealer here in Hawaii, and ordered the TCM, and they sent me the one mounted on the body not the transmission. Is that the correct part i thought the TCM was the one on the Transmission?
And also is that the problem, or did i just order something that is not needed. Also where is the in/out speed sensors located, and if that is the correct name for it.
thanks
Keone
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
RE: Help pls. Codes P0605 & P0700 on a 2001 Dodge Status Transmission
I just changed the TCM, apaarently the one on the transmission isthe transmission solenoid, everything works fine now, the cars shifts normally,and i pulled the codes again, and no codes appeared. As a precaution, i am taking out of the dealer to have it flashed. Hope all of this helps anyone else if they are having the same problems.
