RE: 2000 Stratus headlight switch turns on wipers
You wipers should only turn on when the ignition is on run or accessory. Although the headlight switch and the wiper switch are parts of the same multi-function switch, they are totally two separate wiring diagrams. Please go back and re-check. If the wipers only turn on when the headlight switch is on, then the problem lies on the multi-function switch, and will need to be replaced.
