RE: 2001 dodge stratus not firing
Hello,
I have a 1995 Stratus that had a bad wire in the harness next to the fuse box. It also did not start.It is the connector that has lots of small wires in it. One of them was not pushed down enough to make contact. I pushed it down with a thin, small tool, with a point on it. It was the third one down from the top of the connector, on the right side, if you were facing the front of the car.
Hope it helps!!!!!!!!!!
