RE: '00 ES Stratus 2.5Lv6 Not Starting HELP!
I have a 2000 Dodge Stratus 184K. That the same issue it would start and then turn off and would not start.
I replaced the crank position sensor to resolve the issue. I had no spark to spark plugs after it started and die or if I turned the engine off.
It's is also possible to have a bad PCM or distrubritor assembly.
I also replace the sprark plugs, spark wire set, distrubritor assembly, fuel pump, and fuel filter, I reseated all the relays.
