DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 06-17-2008, 06:47 PM
atimehascome atimehascome is offline
Default '99 Stratus speedometer not work
Hey guys,
My speedometer all of the sudden stopped working. The rpms are also extremely high even if I just barely touch the gas pedal. I was sitting idle trying to get home, and I can hear a clicking here and there. My check engine light just came on as well. I really haven't had many problems with it. It has 96,000 miles on it. I don't quite know how to explain this one, but the car also "jumps" a little every so often. I don't know if it just isn't shifting properly or not. Any help would be great. Thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-18-2008, 02:45 AM
tom01973 tom01973 is offline
Default RE: '99 Stratus speedometer not work
go to autozone and find out what codes are stored in the computer and we can go from there
Old 06-18-2008, 01:08 PM
bad venge's Avatar
bad venge bad venge is offline
Section Moderator
Dodge Forum Moderator
1998 Dodge Avenger
Vehicle: 98 Dodge Avenger
I'm thinking the tranny is in limp mode (stuck in second gear) ... unsure why the speedo would die at the same time though
Old 06-18-2008, 09:57 PM
Well, I went to AZ like you guys said. The codes are P0700 and P0731. Does anyone have any ideas on what they mean. I don't know much about cars, but here is what each one says.
P0731- The PCM has detected an incorrect gear ratio condition in 1st gear.
P0700- Transaxle control system fault. ECM received a signal that the transaxle control module has a fault.
Thanks guys.
I also just changed the tranny fluid/filter, but no luck there either.
Old 06-19-2008, 02:22 AM
sounds like the trans controller has gone crazy.time to go to a trans. shop for further diagnosis
Old 06-19-2008, 01:10 PM
bad venge's Avatar
Section Moderator
1998 Dodge Avenger
Tranny is in limp mode ... Off to the tranny shop
Old 06-19-2008, 03:15 PM
We ended up replacing the output sensor, and it seems to work just fine. My speedometer works, and my tranny shifts again. I hope that's all it was. My check engine light hasn't came back on yet. We'll see what happens in a couple of days.
Tags
control, dodge, fault, p0700, speedometer, system, transaxle, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
