DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 06-17-2008, 07:41 PM
GUANADON GUANADON is offline
Default 2000 stratus won't start
I went out to power the windows up after driving it home from work the other day and with it in accessary mode the driver side window went half way up and stopped. I tried to start it and there was nothin' doin'. So this is the deal when I turn the key to start only the fuel relay clicks and when I return the key to the run pos. the dash lights flash three times (don't know if that means anything). the fuel rail has pressure (replaced the fuel pump last summer). the fuses are all good both under the dash and the hood. the battery has a full charge. Any Ideas.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Don
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-18-2008, 02:15 PM
Default RE: 2000 stratus won't start
Also, with it in accessory mode the windows will go up but they pulse in very short bursts. Help
__________________
Don
Old 06-18-2008, 02:59 PM
bad venge's Avatar
bad venge bad venge is online now
Section Moderator
Dodge Forum Moderator
1998 Dodge Avenger
Vehicle: 98 Dodge Avenger
When you say "won't start " does it CRANK ???
Old 06-18-2008, 09:14 PM
No crank, just fuel relay clicking.
and in accessory mode the entire interior power seems to pulse
__________________
Don
Old 06-19-2008, 01:08 PM
bad venge's Avatar
Section Moderator
1998 Dodge Avenger
start checking the battery cables auxillary fuse block underhood and the wires to the starter
Old 06-19-2008, 07:45 PM
All seems fine there. It seems like it might be ignition or computer related.
__________________
Don
Old 06-19-2008, 10:12 PM
bad venge's Avatar
Section Moderator
1998 Dodge Avenger
I'd bet starter, starter wires, or starter solenoid
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
