DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 06-22-2008, 09:08 PM
Shongo Shongo is offline
Default 95 Stratus, Idles, but trys to die when pressing accelerator
I own a 95 dodge stratus 2.5L V6 ES. I recently had the Solenoid and computer replaced to fix transmission problems. Two days after i got it back from the shop i was warming it up and noticed it idleing a little rough. When i tryed to leave it acted like it wanted to die whenever i pushed on the gas. brought it back to the shop and they said they were getting no codes from the computer. They ran a fuel pressure test which came back fine. They told me it might be the distributor... I went online and found the car had a built in code reader so I tryed running it came back with codes 12, 14, 23, 24, 33 and 55. Found out codes 12, 33 and 55 were unimportant. Code 24 is the throttle position sensor I replaced it, no change. Tryed disconnecting the battery to reset the computer. Tryed running the car again... no change. Checked the code reader again, this time it only sent back codes 12, 23 and 55. Code 23 is Internal air temperature sensor. Could this problem be caused by that sensor? Where is this IAT sensor located? or could it be the distributor? and why did the code 14 ( map sensor) not show upagain after replacing the TPS sensor and reseting the computer? I've spent almost 700$ so far trying to fix my car, getting very frustrated please help [:@]
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-23-2008, 11:56 AM
95stratusES 95stratusES is offline
Default RE: 95 Stratus, Idles, but trys to die when pressing accelerator
I have the same model car as you and was wondering if you could tell me where the built in code reader is located.
Old 06-23-2008, 01:47 PM
ratsttam ratsttam is offline
2000 Dodge Stratus
Vehicle: 1g 2000 ES. V6 6g73 Autostick 41TE. Black Leather with Pioneer MP3/CD/Sirius
The built in code reading procedure is to get in, close all the doors, and turn the key from off to on (do not start) 3-5 times. the numbered codes will show up as a blinking of the Check Engine Light. You can then look up the codes online (they might be somewhere in this forum).
A more detailed method would be to visit your local AutoZone, they do readings for free too with the handheld reader. Only works if the check engine light is on.
http://www.dodgeforum.com/m_144109/tm.htm (prior post regarding built in code reading)
__________________
2000 Stratus ES / V6 / Leather / Tint / 173,500mi
2003 Town & Country Limited / V6 3.8 / Heated Leather / Auto A/C / DVD / 102,000mi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
