DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 07-03-2008, 04:34 AM
dirt_trac_racer_80jr dirt_trac_racer_80jr is offline
Default won't idle.....help plz
Ok so I have my cylinder misfire figured out. It was a broken wire under the dash where they come through the firewall. Now the only issue I have is that it won't idle. It starts fine and runs fine if ur on the gas. Another thing I find weird is when the engine is cold it idles. But when the engine is up to running temp it won't idle. I read that u can set the idle rev on the newer strats. Mine is an 03. Is it possible that I just need 2 set the idle or not. Also how do I do it. I read u do it on the dash with the trip button or sumpin. I have a road trip pland for friday afternoon so itd b nice to get this figured out soon. Help me plz
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
98 neon mtx with:
crane 14 cam, ported and pollished, triple grind valves
75mm bore with high comp pistons, af/x race computer, venom injectors, msd ignition, mopar performance valve springs, cai, dropped and chopped
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-03-2008, 12:02 PM
ratsttam ratsttam is offline
2000 Dodge Stratus
Vehicle: 1g 2000 ES. V6 6g73 Autostick 41TE. Black Leather with Pioneer MP3/CD/Sirius
Default RE: won't idle.....help plz
http://www.dodgeforum.com/m_1320294/tm.htm
maybe this thread can explain the process... we didn't know what it did though.
__________________
2000 Stratus ES / V6 / Leather / Tint / 173,500mi
2003 Town & Country Limited / V6 3.8 / Heated Leather / Auto A/C / DVD / 102,000mi
Old 07-03-2008, 02:04 PM
gpg's Avatar
gpg gpg is offline
2001 Dodge Stratus Coupe
Vehicle: 2001 Stratus SE 2.4L SOHC 4G64
Send a message via AIM to gpg
If you can't duplicate the above, I can record a video of me performing the operation. That's of course if that's what it's actually for though... I have mine set to 1 right now and it seems to be driving the same as it was @ 10. Probably will try 20 to see if there's a difference... Would be interesting if it's idle speed haha
Old 07-03-2008, 02:31 PM
2000 Dodge Stratus
Haha, Thanks for the offer, won't help me either way though, Well see if Dirt Trac Racer wants a video. the [my] first gen that procedure starts a self test of the cluster. the 2nd gens do that number thing.
__________________
Old 07-04-2008, 10:08 AM
ok i tried it and i couldnt get it to work ....so i hold the odometer down and turn the key ...does it matter if its on trip a or trip b or odo....if you could just post the video id reall appreicate it
__________________
98 neon mtx with:
Old 07-06-2008, 02:21 PM
gpg's Avatar
gpg gpg is offline
Yes, it matters (I thought it didn't, but I was trying it recently..)
Here are the steps. I'll try to get a video, but..
1. Turn key to 'ON', and press the Odometer Dash Button several times, until it shows Odometer (not Trip A or Trip B)
2. Turn Key to 'OFF' position.
3. Push and hold the Odometer Dash Button.
4. Turn the key to the 'ON' position, while still holding the Odometer Dash Button.
5. You will hear your car chiming, for about 10 seconds, and your car's self-test lights will be illuminated. The chiming will stop, and the lights will go out. (If this does not happen, just wait 10-12 seconds)
5.5. Release the dash button, and then push it in again. You will see a '10' (or it may show a '10' even after you release, then start at '1' when you start pushing it)
6. Push the button to increment the number. You can choose one from 1-20. It will loop around if you pass the desired setting (what that may be, I have no clue..)
7. When you arrive at the desired number, push and hold the odometer dash button for several seconds, and you will see your odometer reappear.
8. Turn the car to the 'OFF' posistion for good measure, and then start it.
Note: The default setting is 10. Also, we don't know what this actually does.. whether it controls your idle speed, or makes your car fly through the air, it's beyond me. I just know how to do it (: (and it seems like maybe what you are referring to.. setting in the dash, etc..) You should probably make sure that you have checked other things... Have you run fuel injector cleaner recently? If you're low on gas and you did, you may be getting more cleaner than fuel, which will cause you to idle out (that happened to me this past weekend). Just a thought ^^
Hope this helps, and I'll see what I can do about the video, but it will just tell you how to do it, now what it does :]
Tags
6g73, idle, misfire, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
