Dodge Stratus DF Group! Join!
Old 04-17-2013, 11:35 AM
Raist5305's Avatar
Raist5305
Raist5305 is offline
I have a 2005 Dodge Stratus R/T and I can't seem to find any aftermarket body parts for it?
Old 04-17-2013, 11:36 AM
Raist5305's Avatar
Raist5305
And why is it that there isn't a TCS button on these beasts!!??
Old 04-17-2013, 06:04 PM
Obrienpaintwall's Avatar
Obrienpaintwall
Obrienpaintwall is offline
Why is the #5 fuse blowing when put car in reverse? 98 stratus starts on a dime & purrs like a kitten...
Old 07-14-2013, 12:42 PM
Trouble's Avatar
Trouble
Trouble is offline
Can anyone tell me or point me in a direction to find out the length of the cables on my rear passenger power window regulator for my 2005 Dodge Stratus? I'd hate to have to take the other door apart to find out and unable to locate it anywhere online so far.
Yes I'm making them lol oddly iv discovered the cable diameter is the same in a Bell brake and gear cable kit for bicycles
Thanks for any help here guys!
Old 08-12-2013, 12:30 AM
mopar39426ml's Avatar
mopar39426ml
mopar39426ml is offline
Look on top of the column if you haven't already by now for the trac. button, mine has one there.
Old 08-20-2013, 06:17 PM
darynmccoy's Avatar
darynmccoy
darynmccoy is offline
Default 1997 Dodge Stratus-Charging System issues
Hello everyone/anyone,
I have a '97 Dodge Stratus, 5-speed w/ a 2.0 Liter engine, which is having charging issues. Now I have changed out the alternator, starter, and battery on this car.....and even did some minor wiring, cable, and connector changes. I do not know where to go from here besides to have my alternator, battery and starter tested while they are not on the car. Is there possibly a simpler and easier way to find the actual issue??? I'm all eyes and taking suggestions. I'm a young buck trying to put my schooling and time there to use.
I appreciate all who will respond.
Old 10-23-2013, 02:27 PM
bjj2014's Avatar
bjj2014
bjj2014 is offline
is it a slap stick or autostick?
Old 11-14-2013, 01:37 PM
amytodd8440's Avatar
amytodd8440
amytodd8440 is offline
i have a 2004 dodge stratus r/t. having issues with the pass mirror and door locks in unlock mode and dash lights are very dim. Question does this have a body control module tha would need to be replaced? I was told that this has mitsubshi parts and its hard to find parts for.
Old 11-16-2013, 08:35 AM
Stratus-Cat's Avatar
Stratus-Cat
Stratus-Cat is offline
Originally Posted by 01 Dodge ES
So far The answer Is It can not be done. I have A 2001 Dodge Stratus With the 2.7. I know that It Is not recommended to try to put anything else In! The car has only 84000 Miles on it and I would say that It has set most of it's Life. I have heard A lot of Horror Stories about the 2.7 and I don't have A problem rebuilding It. My question Is like many others. Can I put something else In It? Is it possible to put the 05 Motor In the 01 Car since Dodge did make some Improvements on the Engine as the Years went on. Or can I do A transplant with the 3.0 Wiring Harness ECM so on so fourth. I was A Automotive Tech for quite A few Years but had to get out of It due to A chronic back Issue So I am behind on My Technology I would be doing it Myself to say the least. Also will the 2.7 trans work with the 3.0 motor? I would doubt it but just another question. I would appreciate any Information about this Car and the possibilities or lack there of. What can I do to make the 2.7 better! Any Information would be valued If It Is not complete sarcasm! HA HA Thank You For Your Time.
I would put a 3.0 in.... look here for how to https://www.facebook.com/stratus.ca
Old 11-16-2013, 08:36 AM
Stratus-Cat
Here
Quick Reply: Dodge Stratus DF Group! Join!
