DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 11-29-2008, 10:43 PM
hankmavery hankmavery is offline
Default Jumping Starter Relay?
Hello to the Dodge folks,
I've been through several steps with this '96 Dodge Stratus starting system.
I had the 20 amp bus fuse blowing and I replaced the small wire from the solenoid to the starter relay and that worked for 30 starts.
Now it's back to doing nothing when I turn the key.
How can I jump the starter relay just to get it going and possibly bring it to a shop?
Thanks for any replys!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 12-01-2008, 04:30 PM
tomthedog tomthedog is offline
might be time to replace the starter. as elec parts get older thier resistance increases, increasing the load on the circut, just part of the aging process. if you still have the factory starter it's over 13 yrs old, i'd start with the relay if you havn't done so yet, move on to the grounds (batt and engine) as this may also increase the load for your circuts. hope this helps.
Old 12-02-2008, 01:14 AM
Quote:
Hi Tom,
I appreciate your help on this matter.
Maybe it is a problem with the grounds. How do I check these? The starter is a new "used" starter that was tested at the yard. The problem is the same as it was with the old one.
Hank
Old 12-05-2008, 11:26 PM
follow the neg batt lead to where it hooks to the car body, look for junk built up on the connections. same with any cables that hook to/from the enginge block that don't appear to go anywere else but the frame.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
