best bet is to just get one from the dealer, you won't have to worry about the right thead count or bolt strength (it really is a concern). if money is REAL tight check the local junk yards. i would also recomend to use lock tight when installing the replacement bolt. this is a type of glue to help keep the bolt from falling out again. be aware there are diff types, some hold alot stronger than others, you don't want have to drill the bolt out. check with the seller to make sure you have the right type.
