Hi... can anyone tell me an easy way to change the flasher relay on a 2000 2.4l?
thanks.
Should be the same for your stratus, since I just did this.
Take a phillips screw driver and remove the two screws that are located on the trim pice of the steering column(they were on the under side for me). Then seperate the steering column trim into to peices and place it aside, I replaced my relay without taking the whole mfs assembly out. You should see the relay top dead center in the rear of the mfs assmebly slide it out and note how the prongs are to make the installation easier. then just plug the new one in and put the trim panels back on.
Hi... I replaced my flasher today. I went to try it out and it worked for the turn signals but when I tried my hazards I blew the 20a fuse under the hood for them. Anyone have an idea on why this would happen??
Thanks,
Andy
Have you gotten the issue resolved, same thing happens to me when i use
the hazards. Im at a loss now....Thanks in advance.
