DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 05-19-2009, 06:35 PM
pajacobsen pajacobsen is offline
Default 1996 2.0L ATX - Radio failure - tape piece fine
Has 1996 2.0L ATX Plymouth Breeze, OEM radio (tape deck is fine)
Radio will not play (no sound), but tape plays fine. I assume that this is the antenna (no signal = no play), but that is only a hunch, and I do not see anything obvious around the antenna.
Fuses are fine. Radio and all connections look fine (pulled it out and looked at wiring). Antenna and antenna wires look fine.
I would appreciate any help on:
  • Troubleshooting this - possibly providing advice on where else to look
  • Confirming if this is an antenna issues (and if so, how to narrow it down and fix it)
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-19-2009, 08:39 PM
ratsttam ratsttam is offline
2000 Dodge Stratus
Vehicle: 1g 2000 ES. V6 6g73 Autostick 41TE. Black Leather with Pioneer MP3/CD/Sirius
You should be able to hear static as you change channels, and AM uses an internal rod antenna that won't be affected by an FM antenna failure. If you have a friend with a satellite radio or an ipod with fm transmitter, it should be strong enough locally to not need the antenna, also helping to eliminate failure points. Most CD players have come down enough in price, it might just be easier to replace it (unless you're really hooked on having that tape deck )
__________________
2000 Stratus ES / V6 / Leather / Tint / 173,500mi
2003 Town & Country Limited / V6 3.8 / Heated Leather / Auto A/C / DVD / 102,000mi
Old 05-21-2009, 12:23 PM
Default Thanks Ratsttam
Ratsttam,
You wrote:
Quote:
Thanks.
I guess, it is not the antenna, then. I don't want to replace the radio as it is not a size that I see in most cars, so I would not be able to move the radio if/when I abandon the car.
I will try the AM band.... Any other ideas?
Old 05-21-2009, 09:12 PM
2000 Dodge Stratus
Quote:
Originally Posted by pajacobsen View Post
Ratsttam,
You wrote:
Thanks.
From your description, and further testing, your radio has died. Not unheard of... The stratus (and most dodges and older gm's too) use a 1 1/2 din size radio. Most brackets will either add space around the radio, or add a cubby underneath, which is great for storing cd's or other random stuff. Very few radios are that 1.5 din size (pioneer has a couple, but they are more expensive, and frankly, lacking in features). With that, the radio will transfer nicely to a different car later. You could also check online or your local junkyard to see if there is a working OEM radio still available. It's most likely not worth it to have an audio shop or electronics shop try to fix the existing radio. Sometimes it's not worth it to "fix" something rather than replace the broken piece. Frankly the factory tape desk is one of those pieces, IMHO.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
