DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 05-26-2009, 06:48 PM
cnctony cnctony is offline
Vehicle: 1998 ford F150, 1998 Ford Escort, 2000 Dodge Stratus, 2001 Ford Focus, 1994 Toyota 4runner
Default P300 after engine replacement. PCM Conflict?
I have 2000 2.5L Stratus. I removed engine and transmission and swapped engine with used one from Used Auto parts. I replaced spark plugs, wires, cap and rotor. I also flushed engine and new oil and filter. I also drained transmission and replaced filter, fluid and cleaned pan/magnet. I cleaned throttle body, IAC valve, and replaced valve cover gaskets. wweeeheww. OK
Initially the car started and idled perfectly. After running the car for 2 days about 100mi. the check engine came on. I have an OTC Mindreader and upon connecting I get a PCM conflict. I notice the rpms on the transmission PCM and the rpms on the engine ECM are reading differently by a 2- 10 rpms. The engine will idle at 700rpms with a little bump every now and then. I cant register this car with the check engine light on.
My code reader keeps locking up after a few min. I have never had this problem with my code reader before. but this is the first time I have seen 2 PCM's register with my reader.
I read in the transmission manual that If the transmission is replaced that a DRBII scanner needs to be connected and to perform the Transaxle quick learn procedure.
ANY BODY IN HOUSTON OR SURROUNDING AREA'S HAVE A DRBII THAT KNOWS WHAT I AM TALKING ABOUT?
Should I go to dealer? is there a way to set the teach mode without the DRBII?
Is the random missfire something else? any suggestions? HELP. I have also replaced the radiator, hoses, vacuume lines and everything I can think of.
Thanks Anthony
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-26-2009, 09:46 PM
ratsttam ratsttam is offline
2000 Dodge Stratus
Vehicle: 1g 2000 ES. V6 6g73 Autostick 41TE. Black Leather with Pioneer MP3/CD/Sirius
A dodge dealer should have the tool your looking for, it's a long shot to say that any independent shops will have that. Hell, I'm still looking for someone local that can turn off my autolocking doors (BCM programer)!. dealer probably charge quite a bit too to have it adjusted, synced or whatever else it needs.
Is there a possibility that the pcm isn't working quite right?
__________________
2000 Stratus ES / V6 / Leather / Tint / 173,500mi
2003 Town & Country Limited / V6 3.8 / Heated Leather / Auto A/C / DVD / 102,000mi
Old 05-26-2009, 11:41 PM
I think I found part of the problem. The intake plenum has a map sensor and next to it there is a bung for a vacuum line or cap. Does anyone know if there is a vacuum line attached or is it capped off?
Old 05-28-2009, 03:42 PM
2000 Dodge Stratus
I'll have to verify it when I get back home this weekend. But I recall that line (off the left side facing the car from the front?) being attached to something else.
__________________
Old 07-05-2009, 07:37 PM
FIxed my problem, Missing and hesitation caused by bad distributor. I first replaced spark plugs cap and rotor- no change, then replaced the distributor, distributor cap and rotor from junk yard and now is running perfectly. Hope this helps someone else.
Tags
2001, 2003, cap, caravan, check, country, distributor, dodge, engine, engine swap, missfire, neon, p300, pcm, replace, replacement, town
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
