DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 06-09-2009, 10:27 PM
lancejonesmusic lancejonesmusic is offline
Vehicle: 2005 Dodge Stratus coupe
Default What is this part called?
Well, I have an vacuum leak in the throttle body area. when I sprayed carb cleaner around there, my rough idle went up to higher rpms's
I thought it was the throttle body gasket or the IAC valve gasket, but turns out, when I was removing the throttle body to replace the gasket, I say this part below on the end of the throttle body with no screw holding it down.
It has a small O-ring on it, so if since this wasnt screwed down, this Im sure is the source of the vacuum leak.
Well, I pulled it off with ease, and in the hole where it goes the little plastic piece next to it was loose sitting inside.
Looks like the little plastic piece has another half which I cant find...
What is the whole mechanism called? Im going to either get a screw to mount it back on or buy a new one but I dont know what it is lol.
Also, the little plastic piece, where does it go? lol
thanx, Lance
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-10-2009, 01:05 AM
http://www.2gstratus.org/forums/inde...ded&pid=413288
Found another thread where the guy had the exact same idle problem, same codes, and same part loose on the TB lol
Old 06-10-2009, 03:15 AM
Welll tightening down that part on the throttle body did the trick. My idle is smooth is by silk now, purrrs like a kitten-
No engine codes thus far since erasing them so we shall see, but the idle is definitely perfect now!
Old 06-10-2009, 07:38 AM
pearl01stratcpe pearl01stratcpe is offline
Vehicle: 2001 Stratus Coupe
Are you able to get another picture of that piece in the throttle body? I have one sitting here and I can't locate that piece. I'm just curious for future reference.
__________________
Eibach Sportline Springs, KYB GR-2 struts, Muffler delete, CAI, Short throw shifter, 2.5g wheels, Rear Disc Conversion, Eclipse Spoiler and Fuel door, Blacked out headlights, OEM foglights, and a little bit more.
Old 06-10-2009, 11:32 AM
BadStratRT's Avatar
BadStratRT BadStratRT is offline
The DodgeFather
Dodge Forum AdministratorHall of Fame Member
1992 Plymouth Laser
My Garage
Vehicle: 1972 Dodge Demon 340
Send a message via AIM to BadStratRT
was this a 2.4 or 3.0?
__________________
The New Detroit Autos Examiner!
1972 Dodge Demon 340-1983 Dodge Mirada 340-1992 Plymouth Laser RST-2002 Dodge Stratus R/T Coupe-2006 Dodge Ram 1500 Laramie
Old 06-12-2009, 05:22 AM
It was a 2.4 and if looking at the throttle body when it is installed, on the bottom front, about 3 inches below where the sensor is attached to the throttle bod, there is a round metal plate with a screw holding it down. That screw had come out and the plate was partly out so I could see the metal coil a little coming out-
I try to remember to take a picture and circle it while installed in the car as it is in there now-
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
