DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 06-10-2009, 12:39 AM
Titanium Titanium is offline
Default cv shaft or wheel bearing
Need help trying to figure out whether i have a bad wheel bearing or cv shaft on an 02 dodge stratus with a 3.0 v6. It makes a roaring noise as you gain speed and if you turn to the left a little bit the roaring noise will go away. I know for sure its one of the two i just would like to save some money and not buy the wrong thing to find out i needed to buy the other.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-10-2009, 07:41 AM
pearl01stratcpe pearl01stratcpe is online now
Vehicle: 2001 Stratus Coupe
Jack the car up and remove the wheel. Check the CV boot for rips or tears. If so, its good to replace the CV, and then while its out you can check the bearings for tightness.
If its not torn, I think you can jack the car up and grab the wheel, and see if something is loose by rocking it.
__________________
Eibach Sportline Springs, KYB GR-2 struts, Muffler delete, CAI, Short throw shifter, 2.5g wheels, Rear Disc Conversion, Eclipse Spoiler and Fuel door, Blacked out headlights, OEM foglights, and a little bit more.
Old 06-10-2009, 10:43 AM
stratusoutlaw stratusoutlaw is offline
Vehicle: 98 Dodge Stratus 2.0L M/T
You said it goes away when you turn left. What happens when you turn right? It sounds like a wheel bearing though. If it were a CV, you usually get more of a grinding/clunking/popping noise due to the dirt/sand/rocks getting into the joints of the CV. If you turn right and the noise gets louder, it is most likely your LEFT wheel bearing.
PROCEED AT OWN RISK.
If you have access to a lift. You can raise the car, start it, put into drive. You should not need to push the gas pedal, the wheels should start to spin on their own (you may have to stop the opposite side wheel from spinning while doing this.). You can then listen for the noise.
Old 06-10-2009, 08:49 PM
Yea when you turn right the vibration gets worse if that helps at all. im leaning more towards the bearing be junk.
Old 06-10-2009, 10:14 PM
definitely sounds like it's the LF wheel bearing. but you said vibration now. is it more of a scrapping (metal on metal)?
Tags
2001, bearing, bearings, caravan, cv, dodge, durango, left, noise, removal, replace, shaft, stratus, turn, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
