No Spark, No Fire, No Gas....HELP PLEASE.
Stratus no spark or fuel 2.5
I know this one...
Hello, I've owned a used car lot now for 28 years. We have come across this problem several times in the past and in each time we have replaced the DISTRIBUTOR and only the distributor. That alone solved the problem. They cost just under $200.00. When removing the old one, pay very close attention to where the rotor cap is pointed so to install the new one in the exact position.
Ron Hardin
might have better luck posting in the durango section, could be anything sensor,wiring ,computer,ASD relay etc.
i have a dodge stratus and i went to start it one morning and it started for a couple seconds sputterd then died and when i tried to start it again it just turns over but there is no combustion when i try and start it for 5 seconds you can smell gas but there isnt anything happening but turning over. i dont know what to do the no bus light comes on once and a while when im trying to start it. please any help i really need it Thank you
Check all fuses reguardless of what its for then check the pins In the fuse panel one could have been damaged then remove fuse panel and check under where all the wires are for any problems
