DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 08-06-2009, 01:42 PM
Shmitty1 Shmitty1 is offline
Default Problems with a 1999 Dodge Stratus: Dashboard occationally not working after starting
Occasionally (as in once or twice a week), when I start my car, my odometer lights, fuel gauge, speedometer, and other meters don't come on, my AC won't blow cold air and my windshield wipers won't come on. This happens only in the afternoon when it is hot and on the hot days. Yet my car will run like normal. What is wrong and do you think it will be expensive to get fixed?
They come on a few miles into the drive or when I repeatedly turn my lights on and off
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-06-2009, 01:49 PM
ratsttam ratsttam is offline
2000 Dodge Stratus
Vehicle: 1g 2000 ES. V6 6g73 Autostick 41TE. Black Leather with Pioneer MP3/CD/Sirius
my guess is that a solder joint on the back of the cluster is loose, most likely a ground point, since it's not JUST the cluster. If it only does it when it's hot, some parts may have expanded and stopped touching, contract and make contact when they cool off. If you get the car cooled off after a bit do they come back on?
__________________
2000 Stratus ES / V6 / Leather / Tint / 173,500mi
2003 Town & Country Limited / V6 3.8 / Heated Leather / Auto A/C / DVD / 102,000mi
Old 08-06-2009, 01:51 PM
they come on a few miles into the drive or if I repeatedly turn my lights on/off
Old 08-06-2009, 11:33 PM
2000 Dodge Stratus
OK. Start off with your ground points behind the cluster and in the harness that handles the lights (the control arms). If all those wires check out, remove the cluster and make sure there is no broken soldier joints on the back of it.
Not sure why the lights kick it back on... But I know that if I leave my car in the sun all day with the windows full closed, my turn signals don't flash (stay steady on) until it cools down a bit in the car.
__________________
Old 08-07-2009, 11:20 AM
so I likely shouldn't have this problem in the winter?
Old 08-07-2009, 12:21 PM
add|ct add|ct is offline
Vehicle: 1999 Stratus 2.4L with K&N filter/short RAM intake
My car did this when I was on a trip in Mississippi with some friends and one of them started my car with the WRONG KEY. It was a key for my chevy S-10, but it actually started the Stratus. Crazy, right? The same symptoms as you have here. AC didn't work, gauges etc; it was really strange. I was asking myself, "okay, what happened to my car?" Then, to my surprise, we find out my friend had started the thing up with the wrong key to begin with. Ugh! It sounds like ratsttam is on the right track.
Old 08-07-2009, 12:33 PM
2000 Dodge Stratus
Quote:
If the solder joints are heating and cooling, eventually they will work themselves apart to the point that it WON'T work at all... Either way, it's something that should be fixed sooner than later, since it may impact more than just your gauge cluster over time.
__________________
Old 08-08-2009, 11:06 AM
how expensive is it to get that fixed?
Old 08-08-2009, 12:24 PM
It never hurts to ask the dealer, but for some reason any type of electrical work like that on cars, I trust the dealership more than a regular mechanic. At least you'd get an idea of the pricing. Personally, I would use the dealer to fix it, if you can afford it and its definitely the problem.
Old 08-08-2009, 12:37 PM
2000 Dodge Stratus
if you're good with tools, and electronics equipment, you can probably find and fix it yourself, for just a few dollars and a LOT of hours... I don't recall ever seeing your exact problem with the strats, but I know the XBox 360's had the same problem. The joints would come loose from being hot, and stop working. The "ring of death" as it is called.
This is an issue that either you're comfortable working yourself, or is best done by a dealer or independent garage that specializes in electronic issues. Good Luck! Post back and let us know exactly what was found!
__________________
Tags
1999, 1g, dashboard, dodge, find, flasher, problems, starting, stratus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
