DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 08-08-2009, 09:21 PM
Hrntphxr Hrntphxr is offline
Vehicle: 2004 Dodge Stratus R/T Sdn
Default 04 Stratus R/T SDN Front Wheel Bearing
Wheel bearing bad at only 60K miles. Bought new SKF from NAPA for 118.00 each, dealer wanted 265.00 each. Knuckle still installed but- axle nut removed, brake caliper hanging from wire, brake disc removed, bolts out of assembly. Problem is the "hub assembly" won't separate from knuckle. I was told by several mechanics, that I should be able to get this off without removing the knuckle, but this won't come off. I have even tried attaching a slide hammer to the lug nuts. Is it possible these are so tight they are pressed in and out? It is not specifically mentioned in the Chilton manual.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-19-2009, 12:35 PM
jugrnaut69 jugrnaut69 is offline
Hi, I doubt if you are still having this problem. But if there are any others out there having this same problem just spray the mating joints with some WD40. Wait a few minutes, then turn the knuckle until you can see the back of the hub and then take the hammer to it and knock it out. It will take probably a dozen hits or so, but it will come right out.
Tags
2002, 2004, bearing, bearings, change, dakota, dodge, front, hub, removing, rt, separate, stratus, wheel, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
