DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Stratus
Thread Tools Search this Thread
Old 09-27-2009, 09:37 PM
bmc010 bmc010 is offline
Default cam sprockets on a '00 dodge stratus 2.4l
just wondering if any one has any insight as to the best way to pull these off in order to get to the water pump. any and all help would be hugely appreciated. thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-28-2009, 11:13 PM
Molecule Molecule is offline
Mine is 98 model. But I believe it is the same motor or minor different, 2.4L-I. I have to open the valve cover, then lock the rocker arm by putting an socket extended bar into the hole on the arm. Now I am able to use a socket to untight the bolt on the sprocket. I don't have a special tool, so this work out just fine to me.
Old 10-06-2009, 02:03 PM
castlenut castlenut is offline
Stick a bent screw driver or brake spoon just under the center and through the cam where the timing cover bolt is. There is a little notch there. That should give you enough leverage to be able to undo the bolt. On the exhaust cam you may need to get under the car and hold your tool while your buddy unbolts it. I used a brake spoon by the way...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
